Bleeding Brakes problem
Old Aug 12, 2010 | 11:49 AM
jackvtte13's Avatar
jackvtte13
1st Gear
Default Bleeding Brakes problem
I have a 79 that I've bled the brakes twice in the past month without success. The pedal returned to the floor a few days later. I don't see any fluid leaking and thought we did a proper bleed. In a related discussion, a man who is a corvette collector, mechanic, related that a bad wheel bearing could ingress air into the system. My left rear wheel has a significant amount of play (as much as a 1/2 inch). Anyone have experience with a wheel bearing causing air in the brake system? If so, I guess the bearing needs to be replaced before I get the brakes airfree. That might be beyond my ability! Thanks!
Old Aug 12, 2010 | 11:58 AM
SIXFOOTER's Avatar
SIXFOOTER
Its not actually the bearing, but the caliper pumping air into the system because the rotor is wobbling, thats "Runout"
If you have 1/2" in the wheel, stop driving immediately as the wheel is about to fall off.
Once you have the bearings sorted out (thats a whole topic all by itself) then you will need to check/correct the rotor runout. While its apart the lip seals on the caliper may need to be replaced, they wear fast with excessive runout
Old Aug 12, 2010 | 01:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SIXFOOTER
...If you have 1/2" in the wheel, stop driving immediately as the wheel is about to fall off...
Absolutely. The car is not safe.
To Bleeding Brakes problem
