74 Rear Defroster
Old Aug 12, 2010 | 06:18 PM
flaco1801's Avatar
flaco1801
Default 74 Rear Defroster
Does anyone know how the defroster is fed?.. is it pulgged into harness with factory connection into IGN port on fuse block?.. and where is the resistor located in the wiring harness..i assume the resistor is for the low speed... thanks, jeff
Old Aug 12, 2010 | 10:36 PM
Tom73's Avatar
Tom73
Here is the wiring digram for a '73. Would assume that the '74 would be close if not the same.
Old Aug 12, 2010 | 11:10 PM
flaco1801's Avatar
flaco1801
thanks tom.. it appears the tan is plugged into the acc on the fuse block and it has a sister connection for another load if needed... now i just would like to know where the resistor is located.. i have an old harness with a white wire with cloth jacket, wondering if the wire itself is the resistor... thanks.
To 74 Rear Defroster
