'71 starting issues
Old Aug 29, 2010 | 03:52 PM
pwsusi's Avatar
pwsusi
Default '71 starting issues
Having issues starting my '71 LT-1. The car turns over but won't start. When i turn the key back into the off position after letting it turn for a while sometimes i can get it to catch and the car will start....it's hit or miss though. The battery is brand new so i know that isn't the issue. I believe the car has the original ignition coil and TI amp is there but appears to be not hooked up. Ideas?
Paul
Old Sep 1, 2010 | 11:40 AM
Vetteran'81's Avatar
Vetteran'81
Might get a lot better response over in the tech section. Good luck!
Old Sep 1, 2010 | 09:18 PM
AOS_L79's Avatar
AOS_L79
You need a wiring diagram to determine whether you need a ballast resistor or there is a good built in resistance wire. There is the start circuit and the run circuit. It sounds like the start circuit isn't good. Also, a TI coil may not be best for a points-type ignition system, which is what it sounds like you have now.
Old Sep 2, 2010 | 05:09 AM
pwsusi's Avatar
pwsusi
thanks for your reply. i'll check into it
Old Sep 2, 2010 | 10:07 PM
myk7's Avatar
myk7
Check the R terminal on your starter solenoid. I believe that wire should be going to the + terminal on your coil. The LT1 wiring may be different with the transisterized ignition though.
To '71 starting issues
