Front Brake rotor question?
Old Aug 30, 2010 | 12:41 PM
Clams Canino's Avatar
Clams Canino
Default Front Brake rotor question?
Which one is factory - if either?
1. Both have been there since at least the late 70's.
2. Both had all the rivets in place when I took tthem apart last month.
3. Both are in real good shape - sandblast and go shape.
One rotor is marked: "MIN. THICK 1.215
The other is marked with just a "K"
-W
Old Aug 30, 2010 | 01:03 PM
70BBvert's Avatar
70BBvert
-W
Both of my originals are marked "MIN. THICK 1.215"
Jim
Old Aug 30, 2010 | 01:06 PM
Mike Ward's Avatar
Mike Ward
Either/both/neither could be original. GM sold pre-assembled hubs and rotors over the counter for many years .
Old Aug 30, 2010 | 01:13 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
yep. BTW why would you be blasting a rotor?
Old Aug 30, 2010 | 02:00 PM
Clams Canino
To break the glaze without altering the run-out, like turning it would - of course.
(You also mark the hub position so as to return them to the same orientaion on thier hubs.)
You blast it to de-glaze it. And then you take a wire brush wheel (or sandpaper) to the platters to kill the blast roughness. The end result is a pretty near perfect rotor surface - ready to break in with new pads.
-W
Old Aug 30, 2010 | 02:03 PM
Clams Canino
That does kinda seem like the logical way to sell them if you think about it.
Oh well.... I was just curious.
Both of them are near perfect and easily on my re-use list.
-W
To Front Brake rotor question?
