Vacuum hose change.
Old Aug 31, 2010 | 08:33 PM
Carlos840's Avatar
Carlos840
Default Vacuum hose change.
Hi,
Im about to change my vacuum hoses in my 76.
I am just wondering if i need to remove the dash to be able to change the hoses going to the head light switch or if there is a way to do it from under without taking it all apart?
Cheers
Old Sep 1, 2010 | 09:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You may not have to remove the dash, but you are going to have to have space to get to the light switch.
Do the hoses to the light switch need to be replaced? If they are not leaking, I believe I could learn to live with them.
Old Sep 1, 2010 | 09:06 AM
Carlos840's Avatar
Carlos840
Dont need to change them, just got them in my kit so i though i would change it all!
I guess i could just change the one going from the override to the relays...
Old Sep 1, 2010 | 09:21 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Getting in there to replace them is not worth the headache if they are not leaking!
Old Sep 1, 2010 | 09:24 AM
Carlos840's Avatar
Carlos840
Is it possible to change the one going from override switch to the relays without to much trouble?
To Vacuum hose change.
