Ok---I put a long style L88 hood on my '70. Windshield wipers were working before I took off the WS wiper door and grill. Plugged the vacuum lines and put a jumper wire where the WS wiper override switch (under sterring column) was. Wipers do not work. Any ideas?
Did you put a jumper at the wiper door limit switch?
There is a switch on the firewall, which I believe is the limit switch. This switch has 3 wires coming off of it. Is this the switch you are referring to? If so, do you know which wires to put a jumper on. The document which came with the hood didn't say anything about the limit switch.
Here is a picture from my '68, my index finger is pointing to the limit switch and you can see the connector from the switch.
Here's the connector you need to jumper to to left that plugs into to limit switch, it comes out of the taped harness in the background and one of the wires loop into the 3 prong connector on the right.
