Gas Leak...
Old Sep 9, 2010 | 03:47 PM
sil68's Avatar
sil68
Default Gas Leak...
I have a gas leak that looks like it is coming from the canister???? anyone ever had this issue. have not got a chance to look in detail, but at a glance I can see it leaking from that area. any advice would be appreciated. 81 corvette.
Old Sep 9, 2010 | 10:02 PM
Johnny_Johnson's Avatar
Johnny_Johnson
I had a gas leak from the canister on a '73. Only happened when I filled the tank more than ~3/4 full. Never was able to discover what was causing the problem so I finally changed over to a vented system.
Later,
JJ
Old Nov 23, 2010 | 10:53 AM
Helifreek's Avatar
Helifreek
Default Gas leak when full or near full.
Later,
JJ
Is that the black box on the drivers side of the tank? It's up high and has 2 hoses connected to it? Mine was leaking last night after a fillup. I siphoned about 4 gallons out and the leak stopped. It was also leaking onto my drivers side muffler. BTW, my vette is a '73 also.
Mark
Old Nov 23, 2010 | 11:06 AM
Helifreek's Avatar
Helifreek
OK, if I just looked a little harder I would have found the answer.
The little black box is the separator valve/Vapor Separator. It also looks like I may need a new vapor canister as well.
Mark
Old Nov 23, 2010 | 12:05 PM
Mashman's Avatar
Mashman
Mark
I noticed that my seperator wasn't working when I went to fill up, I no longer had the vacuum/suction when I removed the gas cap. I believe that if the system is working correctly, when you remove the gas cap, you should feel the vacuum that has built up.
Old Nov 23, 2010 | 03:50 PM
Helifreek's Avatar
Helifreek
I haven't noticed any vacuum/suction when I remove the gas cap, but I have only filled it up once and it was noisy at the gas station. I'll check for the vacuum/suction when I get home today. I'm still going to get the liquid/vapor seperator thing to replace. From Zip-Corvettes.
Mark
Old Jan 24, 2011 | 04:35 PM
Helifreek's Avatar
Helifreek
I have found it was the vapor liquid seperator, the bottom of the device has a split in it. I have since ordered and received the part. I am just waiting for the weather to get warmer so I can instal said device.
To Gas Leak...
