runs rough - a little help
Old Sep 9, 2010 | 06:50 PM
a17mike's Avatar
a17mike
St. Jude Donor '09-'10-'11-'12-'13-'14,’18
Default runs rough - a little help
OK
I have a 1972 L-40 350 that has been bored 40 over and has a mild Comp cam and TRW innerards (done in the '90's).I bought her in 2008.
She was running a little rich and and looking at the points and plugs it was time to make a change. She has always ran great with no issues.
I installed new Accel points and condenser and new Bosch Platinum Plus spark plugs.
The plugs were pre-gapped - I checked them all at .035 per spec.
The dwell is set at 30
I have set the advance between 4º and 12º and although it runs seemly OK with the advance at 8º & 12º - it won't accelerate smoothly.
It breaks up under hard acceleration above a certain RPM.
I double checked that I had the correct plugs, points, and condenser and I do.
I didn't check the dwell before I started but the advance was at 12º.
Any ideas would be appreciated.
Mike
Old Sep 9, 2010 | 07:26 PM
Phil Zell's Avatar
Phil Zell
Mike,
Check out the timing sticky at the top of tech/performance.
You cannot set your timing the way it was when your car was new.
Old Sep 9, 2010 | 09:22 PM
johnnygascon's Avatar
johnnygascon
was it running like this before your tune up?
Old Sep 9, 2010 | 09:53 PM
depdep3's Avatar
depdep3
Did you check for a vacuum leak?
Old Sep 9, 2010 | 10:51 PM
a17mike's Avatar
a17mike
Originally Posted by Phil Zell
Mike,
I'll check it out.
No it ran pretty well.
No, I will
Mike
Old Sep 10, 2010 | 09:50 AM
Timsride's Avatar
Timsride
I don't think this is Your problem but I have never had any luck with the bosch platinums on these motors. They start off fine and then soon after run like crap. I only use NGK's now.
Old Sep 15, 2010 | 09:31 PM
a17mike's Avatar
a17mike
Found problem - I pulled vacuum line off TCS when setting timing and PO had plugged the second outlet on the back of the switch. I inadvertently eliminated his plug, so I had a vacuum leak.
Thanks for all the help.
Mike
To runs rough - a little help
