My car baffles me evrytime i turn around
trim tag/vin/registration say its an 80
The floor boards look fiberglass(no rot)
the fuel door emblem looks 75ish?
Yes its a vert conversion
As garage-ghost said, the sheet metal floors were added in 76, and they were used through 82.
The 2" and 4" bolsters can be found in any 79-82, I believe. If I remember correctly, GM's supplier was having trouble producing enough seats, so GM contracted with a second supplier. Apparently one supplier did the cushions with 2" bolsters and one company did them as 4 inchers.
I'm sure your convertible conversion has an 80 title, VIN and trim tag because it started life as an 80 coupe. It was pretty common to do a convertible conversions, using a rear clip from a wrecked convertible donor car. If yours does have a fiberglass floor, I would guess that whoever did the conversion, used a complete 74-75 rear clip, from the cowl back.
Hmmmmm... I thought they went back to glass floors in '78....
i was piddlin around under my vette a 77 this past weekend and noticed my floors are glass, but my buddys 80 are metal and they were rotted through in a couple places
Is it possible that the conversion was built using two cars? Perhaps there was registration papers for the '80 and none for the other car so it was registered as an '80. Can you check and see what VIN is on the frame rail?
Look again. Your floor pans should be metal. Do the magnet trick.
Help? I'm in the finishing stages of my 75 vette 7 year frame off project. I had to replace both original interior quarter trim panels with a set I got off ebay. The ebay set is really nice and from the the same year yet, I am going crazy trying to get them to fit around the rear window trim molding.
