Front end repair
Old Sep 23, 2010 | 05:30 PM
Islandcorvette's Avatar
Islandcorvette
5th Gear
Default Front end repair
Hi all, just bought a 1976 vette L48 with some front damage. I will purchase full new front end and bumper. However, the steel front bumper reinforcement has also suffered some damage (bending) on the left side. Seen the weight of this thing, I was actually wondering whether the front end can be assembled without using this steel front bumper reinforcement. Also find it hard to get this replacement part. Please help!
Old Sep 24, 2010 | 12:46 AM
Spook's Avatar
Spook
I'm not sure you'd want to leave the actual bumper metal out of the car. It lines up quite a bit of the nose and holds much of the other various supports together. I currently have mine out of the car and the play with the sides and whatnot is amazing. Not to mention that is where your signal lights and grills mount.
You didn't share any pics but I'd imagine you could repair it. Lots of heat and even more muscle... if you aren't down for it go to a real auto body shop and ask them to quote you for getting it back in line.
Other options would be to find some salvaged parts. I'm not exactly in-the-know there but hopefully some other members can point you at some decent part houses.
BUMP
Old Sep 24, 2010 | 06:17 AM
Makonut's Avatar
Makonut
Scroll thru these and see if it would help.
http://www.parts123.com/parts123/yb.dll?parta~partsort
Old Sep 24, 2010 | 07:56 AM
Islandcorvette
5th Gear
Thanks for the input guys. Will let you know about my decision.
Old Sep 24, 2010 | 08:04 AM
Islandcorvette
5th Gear
Makonut I tried to click on the link you provided but says its invalid or something. Is the link correct?
Old Sep 24, 2010 | 12:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Island: you may want to consider having what you have straightened by a frame shop. It's possible your damaged parts can be pulled back into shape.
Old Sep 24, 2010 | 02:46 PM
Makonut's Avatar
Makonut
Sorry.
Try this and just fill in 1976 and bumper.
http://www.parts123.com/parts123/yb....rt~51~cadefibG
To Front end repair
