Help to ID
Old Sep 24, 2010 | 12:27 PM
69ragvette's Avatar
69ragvette
Default Help to ID
hey guys,I decided to try and figure out what this motor actually is. the #T0730hc and below that the #7y192078 appears on the pad any help you can give would be apprieciated I have been told it was a 66 vette 327 but every 327 being sold is a vette motor? thank you.
Old Sep 24, 2010 | 12:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 69ragvette
...T0730hc...
T Tonawanda, New York engine facilty
0730 date engine was assembled at Tonawanda
HC suffix code for 65-68 327 250 or 275hp engines for passenger autos. Not a Corvette block.
...7y192078...
VIN derivitive of the vehicle the engine was originally installed in. I'm guessing 7 for 1967, Y for the plant code, and 192078 for the consecutive unit number.
My reference does not list a Y as a plant code. Are you sure it's a Y?
Old Sep 24, 2010 | 01:21 PM
69ragvette's Avatar
69ragvette
Default code
yes definetly a y, date code is G236 cast#3903352 I kept getting 65 0r 67 never 66 thought it would be good to know if I had another members eng he may like to have it back for his car.thank you
Old Sep 24, 2010 | 02:37 PM
Easy Mike's Avatar
Easy Mike
...G236...
G July
23 23rd
6 almost certainly 1966.
Jives since the block had to be cast before it could be machined and assembled.
Old Sep 24, 2010 | 03:00 PM
68ragtop69's Avatar
68ragtop69
MD Events Coordinator
2015 C3 of Year Finalist
Cruise-In X Veteran
CI-X Car Show Winner
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
cast#3903352
That's a 1967 casting number for a 327
Old Sep 24, 2010 | 03:03 PM
69ragvette's Avatar
69ragvette
Default codes
thank you,a nothing motor for a nothing car.yep its the correct engine for my car.but it sure runs good and has a little power
Old Sep 24, 2010 | 03:10 PM
68ragtop69's Avatar
68ragtop69
Cruise-In X Veteran
This 327 may be out of a Chevy II/Nova.........."Y" was the Wilmington, Delaware assembly plant for these cars....
Old Sep 24, 2010 | 03:18 PM
68ragtop69's Avatar
68ragtop69
Cruise-In X Veteran
Although I'm running a 502 now, I loved my 327 in my last 68. It was the original motor but it was bored .60 over and was a fun motor for that car!!!!
Old Sep 24, 2010 | 05:21 PM
joewill's Avatar
joewill
a july 23rd 1966 motor engine block casting date would probably work better for a early 67 vs a late 66 car.. if they started building the 67 model year in august/september 66
Y = chevy passenger car biscayne, belair,impalla or caprice and the HC is a 327/275 with a powerglide, again on a big chevy.
according to my book, it is a one year only casting.. not really a nothing motor..
Old Sep 24, 2010 | 05:39 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by 68ragtop69
This ..."Y" was the Wilmington, Delaware assembly plant for these cars....
Thank you. I couldn't find Y.
Old Sep 26, 2010 | 10:01 AM
69ragvette's Avatar
69ragvette
Default motor
thanks for all the info,this 327 was bored 60 11.5 to 1 compression with humpty hump cam and world products heads I have had this to 7500 rpm . it pulls pretty hard the guy spent a lot of bucks at a local machine shop and I picked it up for a 1000
To Help to ID
