Corvette Central has one that is a decent pressure bleeder. I used it for two cars, then the piece that fit over the master cylinder broke (it's plastic). I finished the bleeding with a Mighty Vac vacuum system.
The company was good about replacing the broken part but be aware that it's very brittle when cold (below 40 degrees).
This is the brake fluid that I flushed out of my '95 LT1. Remember, brake fluid is suppose to be clear. This stuff is a black as black gets.
Motive is the way to go. I also have a Speed Bleeder on my hydraulic clutch line and that works great also. So I would say Motive first followed by a set of Speed Bleeders.
I use the Harbor Freight one man bleeder. Works great and it's $3.99. I bleed brakes all the time on the racecar. Don't know why anyone would need anything more than this.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I use that too cost me 5 bucks, unless you are flushing or replacing the lines and refilling the m/c etc that little bottle sticks to the rotor, give the brake a few pumps get out and take a look and when you don't see any bubbles in the clear line it is done.
I used it all the time with my old brakes that were lip seal and used to get air in them
