rear compartment
Old Sep 30, 2010 | 12:00 PM
Wood1980's Avatar
Wood1980
Default rear compartment
I am installing new carpet in the 1980. My question is for the rear carpet section. Where should the carpet be cut for proper placing of the 2-door rear compartment frame?
Should the carpet be cut over the hump and onto the inner lip of the metal car frame compartments? Should it be lapped over onto the surface of the metal car frame where the screws go through the compartment and into the frame? Or should the carpet end just under the lip of the frame of the ABS plastic compartment frame?
[IMG][/IMG]
Old Sep 30, 2010 | 12:26 PM
Wood1980's Avatar
Wood1980
As an add...installed hush matt in that area as well. The hushmatt stops at the top of the rounded hump area.
Old Sep 30, 2010 | 01:26 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Where'd you get your carpet set? http://www.ecklers.com/corvette-carp...late-1980.html This one from Eckler's shows one piece. It might need a trim here and there but should not need to be cut.
To rear compartment
