Ground problem in the headlight?
Old Oct 1, 2010 | 10:01 AM
Makonut's Avatar
Makonut
Default Ground problem in the headlight?
Okay,
the low beam on the drivers side does not work on the regular setting. But when I hit the high beam switch, it works fine. Passenger side functions 100 percent on the money. Is it more than likely a ground problem? I hate electrical gremlins on a fiberglass body.
Old Oct 1, 2010 | 11:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bad headlight. The low beams are two element lamps. One of the elements is working, the other isn't.
Old Oct 1, 2010 | 02:45 PM
Makonut's Avatar
Makonut
Thanks Mike.
A lot easier to replace a headlight than track down a grounding problem.
Old Oct 1, 2010 | 02:48 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Makonut
Thanks Mike.
I hear that. FWIW: the forward lamp harness grounds up on the front of the radiator support. Peek around up in there and you'll see it.
Old Oct 2, 2010 | 07:05 PM
Dantana's Avatar
Dantana
I have just spent days and weeks goign through the headlight circuit. Hopefully you can get out of it with just the bulb, sounds like you got it.
To Ground problem in the headlight?
