Hood Kickdown switch
Old Oct 3, 2010 | 02:21 PM
Skip Burney's Avatar
Skip Burney
Default Hood Kickdown switch
Does the hood kickdown switch connect to the switch on the gas pedal? I had to take 3 weeks off and now almost forgot where I was.
Old Oct 3, 2010 | 03:30 PM
redwingvette's Avatar
redwingvette
If you are asking about the cowl induction door on the 73-75 hood then the answer is yes. It is mounted to the pedal and is activated by the accelerator pedal at full throttle. The switch also activates the downshift for the TH400 transmission if you have that.
Old Oct 3, 2010 | 03:35 PM
Skip Burney
My hood dosn`t have a cowl induction door on it and it`s a 4 speed car
Old Oct 3, 2010 | 03:44 PM
Blue73Shark's Avatar
Blue73Shark
My 73 4 speed has the cowl induction door and it operates correctly. Some remove it or block it permanently open.
To Hood Kickdown switch
