I even put an aftermarket smaller diameter steering wheel in my '72 and it was not very much above my thighs. Ended up buying a tilt-tele column, rebuilding it, and installing it - much better now!
Originally Posted by panicman
I also thought about a tilt column, it seems like the best solution.
Yeh, I did also, not much of a fan of bus driver wheels in a vette....
one of the very first things I did, in fact....later shark wheel....
Unfortunately there are no original equipment tilt or T&T steering columns for the 1968 Vette. 1969 had a T&T column option but it was a basic new design and won't retrofit to a 1968. And as you might be aware, I am not a fan of aftermarket steering columns. http://jimshea.corvettefaq.com/wp-co...gid-design.doc
Jim
I did not know a later year T&T column would not fit and I will not use an aftermarket one.
What would you suggest?
I don't want to change the steering wheel but I will if that is all I can do.
