572 Implant 1968 Vert
Old Oct 7, 2010 | 03:22 PM
ajrothm's Avatar
ajrothm
Both of your engine compartments look REALLY good!
Although I would think that 572" would make more then 620hp... it must be pretty mild.....Awesome street engine...
Keep us updated on the build...
Old Oct 7, 2010 | 03:34 PM
lowkeytow's Avatar
lowkeytow
You can get the Performance Parts ZZ572 620 horsepower and 650 lb.-ft. of torque
Or the The ZZ572/720R is rated at 720 horsepower at 6250 rpm and 685 lb.-ft. of torque at 4500 rpm.
The 720 needs race gas 12:1 compression
You can start with a short block and build it up about whatever HP you want.
I decided the anything near 620 is plenty for my application. Just cruising.
Old Oct 8, 2010 | 09:52 AM
65 DENCO's Avatar
65 DENCO
Auto or stick? wondering about the clutch linkage cross shaft. I am in procsess of installing a gen 6 with no pivot ball mount on the block. I used a scoggin dickey bracket. Although the cross shaft hit the header as the ball is farther away from the block. I need to break the weld on the vertical shaft and move it torward the motor 3/8.
Nice deal with the 572 the c3's look to have NO master cyl clearance issues with the GM perf V covers. Mine did
Old Oct 8, 2010 | 09:51 PM
3JsVette's Avatar
3JsVette
I couldn't agree more. Very impressive!
Old Dec 9, 2010 | 10:35 AM
lowkeytow's Avatar
lowkeytow
Here is some video got her started.
http://www.youtube.com/watch?v=aC_C6FemyPY
Old Dec 9, 2010 | 05:15 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
Sick! That thing is nasty!
Will
