Power Windows
Do you use the same window regulator?
Did you use the stock wiring harness,relay and switches?
Are the stock motors available?
I am asking because I found a nice 72 convertible with manual windows and after I have had power windows I do not want to lean across the passenger seat to lower the window.
Biggest problem will be what to do with interior doors panels with window crank holes in them after you go to power windows.
The motors are readily available in either new or rebuilt. .
In the console, the reinforcement already has the holes for the switches, and you can cut the holes in the console. You'll need a power window relay if you are doing this on a 1968-1978 car.
Humm.. What else...
Oh, you'll also need the boots (called Conduit) for between the door and door jamb area, this keeps the harness from getting pinched when you pass it through the door. Mike had the best suggestion and that would be to purchase an assembly manual.
I think that about covers it.
Here is a breakdown of the parts and prices.
Power Window Harness 131.88
http://willcoxcorvette.com/product_i...ducts_id=26204
Power Window Relay 23.95
http://willcoxcorvette.com/product_i...ducts_id=25786.
Regulators range from 125.00 to 174.79 depending on which one you want.
US made route 174.79
Power Window Regulator US. LH
http://willcoxcorvette.com/product_i...oducts_id=4131
Power Window Regulator US RH
http://willcoxcorvette.com/product_i...oducts_id=4132
Cheaper route: 125.00 ea.
Power Window Regulator Imported LH
http://willcoxcorvette.com/product_i...ducts_id=26753
Power Window Regulator Imported RH
http://willcoxcorvette.com/product_i...ducts_id=26754
Power window concuit 13.00
http://willcoxcorvette.com/product_i...ducts_id=26315
2 required.
Power Window Motor New no Core is the way to go! 80.00 ea side.
Right Hand Side
http://willcoxcorvette.com/product_i...ducts_id=26856
Left Hand Side
http://willcoxcorvette.com/product_i...ducts_id=26855
Power Window Switch 16.99 ea.
http://willcoxcorvette.com/product_i...ducts_id=24054
Some motors are very slow. 10 years ago I went out of my way to get a nos motor, and it turned out to be slow. I've heard the new replacements are strong and fast.
