Quick question on strut cam bolts
Old Oct 7, 2010 | 01:21 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Quick question on strut cam bolts
I just changed out my strut rod bushings to urethane on my 82. When I removed the cam bolts, I dummied out and did not mark the position. My question is should the marks on the cam be pointing up or down?
I did a quick search and there was a post that said the assembly manual shows them pointing down but does not specify. I'm pretty sure mine were pointing up when I removed them. As for rear alignment, the shop I use is only 2 miles away. I won't be doing the alignment until I've replaced the control arm bushings up front.
I haven't re-mounted the rear spring yet so if I need to change the cam orientation, I can very easily. Thanks.
Old Oct 8, 2010 | 04:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm not sure it makes any real difference. Go with the AIM diagram.
FWIW: the entire rear suspension was installed while the frame was on its back, upside down. The orientation of the marks may have been nothing more than an aid to the assemblers to eyeball initial settings.
Note frame is upsidedown on its back. Frame on the right has already been flipped and fuel tank has been set in place.
Old Oct 8, 2010 | 05:37 PM
...Roger...'s Avatar
...Roger...
I might be crazy but I always felt the adjustment "stayed put" better with the cams in the up position.
Old Oct 9, 2010 | 09:28 PM
Tally Ho's Avatar
Tally Ho
Thanks all. I'll leave them in the up position where I found them.
To Quick question on strut cam bolts
