I.D.ING #'s
Old Oct 9, 2010 | 10:41 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Default I.D.ING #'s
I took the #'s down from my 77 motor. The front passenger side plate reads 0219 CLA. I know cla means L48 4 barr. What does the 0219 represent? Also on the drivers side rear of engine I see 3970010 on the bell housing, What does this stand for? My vin is 1Z37L75424324,Trim Tag reads 66 L paint and Trim 642, I know what they mean But there is also a #C25, What does this mean? My engine matches the vin # of the car. Thanks.
Old Oct 10, 2010 | 09:56 AM
BKarol's Avatar
BKarol
Are you sure that C is not a G? otherwise the trim tag was attached on 10/25/76 (C25) when the vin shows the car was built in Feb 1977 (G). Then it would appear it is the wrong trim plate.
http://corvette-world.com/corvette_1...te%20Codes.php
Old Oct 10, 2010 | 10:04 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...there should be a "V" designating Flint Engine Plant before that "0219" which would be Feb 19(of 1977). Opposite that 3970010 almost near the top, but towards the pass side will also be a casting date for example A217 for the engine block, which would be January 21, 1977.
Old Oct 10, 2010 | 11:21 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
I believe there is a v there. It was late at night and I was looking with a flashlight. I remeber seeing somthing but could'nt make it out. It was not as clear as the rest of the #'s that followed. As for the c25, I will look again tonight when I get off from work. Thank you guys!!!
To I.D.ING #'s
