Weiand air strike intake will solve the problem if we are talking small block. On the Weiand the vac fitting is located further out on the runner and you will not need a spacer.
When I bought my car, it had a 10" cleaner on it. Didn't like it so I got 14". Soo, yea you can get a drop base for 10" cleaners. For the price and headache I think a 14" is a better way to go.
Use a low-pro vacuum port fitting #5183 from Mo's Speed street rod shop, then you need a 1/2" spacer, fitting comes with all the vacuum parts. And switch to a 14" air cleaner, alot less headaches...
