My '76 restoration (long post)
#502
Since I had the 3D software up and running I took the time to pack together the existing mods (exhaust tips, flare and western wheels), with those coming (slanted window, hollow taillight) and those that are dreamed about (rear window louver).
This is what the back should look if I have all the time and resources I need this winter.
Note: current hood shape is irrelevant.
Loehr69 (03-09-2023)
#503
C3 of Year Winner (appearance mods) 2019
That is really cool. What software are you using for the renders?
The cars gonna be really sweet, and definitely unique.
#504
3DS max is my weapon of choice when to come to CG.
Yesterday I toyed with the rear diffuser idea, and to be frank, all I tried looked goofy.
That's what's cool with 3D, you got all the carbon fiber you want.
I spend most of the night fitting giant spoiler, wings and whatnot, that was gory.
#505
I'd take more Mondays like this one anytime!
Look what I brought from the border :
VBnP double mount, front and back.
Plus a 2-way alarm system.
Can't wait to put those one....
#506
Best of luck with your awesome project, keep up the great work.
Steve
#508
Rear suspension kit installed :
Funny how things come full circle.
The differential was the only part that got transferred from the rotten frame to the donor frame without any restoration.
Back then I considered the state of the whole assembly good enough.
As I had to remove the cross member to drill it, I took the time to finally restore it. unsurprisingly, under the paint I found a lot of rust. As usual, I ground to metal, phosphoric acid treatment and POR15 coating.
#511
But really, that's a pretty neat setup that is adjustable. Also, what does it take to change the adjustment?
#512
Another virtue of the dual mount is that it act like a natural antiroll bar, so I don't need one installed in the back.
That lead me to question whether I need to keep the front antiroll bar, or install a smaller one. I gonna need to look this up.
Yeah that's a cool looking setup, the one I always wanted, so may I repeat, I feel like Xmass
#513
Maybe some of you did notice, in my lastest picture you could see I was missing two bolt for the gas tank shield (top of picture).
I spotted them after posting, and now it's fixed.
I finished the back, installed long TA bolt.
The dual mount spring seems to be smaller than the single one, and I'm pleasantly surprised by how much clearance I get from the tire.
Then I had the chance to see expected stance of the car for the first time.
Driver side:
Passenger side:
The passenger side tire seems to stick out a little more.
It's been doing that since the beginning, I try not to worry about that, betting it would get resolved after an alignment and some rolling.
I did not take it into account when flaring, it's 1.4" on each sides.
Driver side:
Passenger side:
#517
Driver side weatherstrip and striker pin installed.
I have to sand some area that actually had overbuild.
Once fixed, door closes nicely.
In the meantime I rehearsed the back window cut on the spare back clip.
I'm glad I did, the area is more complicated than it seems, and yeah I didn't bother reading the AIM, the spare part was there to be sacrified anyway.
It's been hanging in the garden for a couple of years to my SO's dismay.
No pictures, way to gory.
Now I feel prepared on the procedure.
It's like the front clip, it can take time until I decide to jump in.
#518
Looking really good there, with the flares and the front suspension, but I'm looking at the bolts hanging down on the outsides, next to the front tires on the bottom. Does that cinch up and rise higher, later on in the build?
#520
Good call on the bolt, when I installed them they seemed sufficiently away from the tire, away enough to let the tire deform under load, but I'll give it a second inspection just to be sure.
As always, thanks guy for watching and commenting
