Shifting into Reverse
Old Oct 15, 2010 | 08:59 AM
Peeps9823's Avatar
Peeps9823
Default Shifting into Reverse
xxx
Old Oct 15, 2010 | 09:04 AM
...Roger...'s Avatar
...Roger...
You need to adjust the linkage or check for loose mounting bolts and linkage.
Old Oct 15, 2010 | 09:09 AM
Peeps9823's Avatar
Peeps9823
xxx
Old Oct 15, 2010 | 09:19 AM
...Roger...
Both.... If the 3 levers that attach to the side of the trans towards the front loosen it can throw off the alignment. If the bolts that attach the shifter to the car loosen it can throw off the alignment also. Chances are if this has happened recently you have some loose bolts.
Old Oct 15, 2010 | 09:27 AM
GD70's Avatar
GD70
Also make sure the levers on the tranny are tight. Vibration can loosen them.
Old Oct 15, 2010 | 12:34 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
that it is probably a linkage adjustment problem, but it might also be as simple as putting some lubricant on the reverse lock out mechanism at the base of the shifter mechanism.
To Shifting into Reverse
