windshield wiper problem
Old Oct 15, 2010 | 11:57 AM
stoli's Avatar
stoli
Default windshield wiper problem
I'm having a little problem trouble shooting where my problem with my wipers are at. I can't get them to work/or turn on. I have a new motor and the fuse is still good. I have started checking where I lose power but I don't really know where to start. Any help or guidence would be great.
Old Oct 15, 2010 | 12:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the over ride under the dash. If it's inadvertently on, it's trying to stop the wipers on the windshield.
Old Oct 15, 2010 | 12:37 PM
jotto's Avatar
jotto
Check this out from Willcox! Assuming you have the 76 in your profile...
and
Old Jun 21, 2014 | 04:20 PM
Perpendicular's Avatar
Perpendicular
Cruising
and
I need some help -
I am working on the wipers of a 68 and have been trying to track down the issue and really hope I have found it! In the above pic, the last one with the resistor on it - where does the bare wire connect to? Mine was floating it looks like and I presume it should be connected.
Old Jun 22, 2014 | 10:36 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Perpendicular-
That wire is the end of the resistor, when installed it makes contact with the case of the motor.
But you should always start a new thread, most won't look at a four year old thread that is bumped. But lots will look for a new thread.
Here is a bunch of info on your 68 wiper motor.
Wiper Motor Bench Test 68 Ver 1
Wiper Motor Bench Test 68 Ver 2 "Follow up"
Great threads on 68 Wiper motors can be found here:
Mister Willcox, 68 wiper motor
68 wiper problems
Wiper Motor Bench Test 69-72
Wiper Motor Wire Testing
1973-1982 Wiper Motor Testing.
To windshield wiper problem
