shell swap
Old Oct 15, 2010 | 03:57 PM
58impala's Avatar
58impala
Default shell swap
Can anyone tell me if a '72 body shell will bolt to a '75 frame easily?
Old Oct 15, 2010 | 04:33 PM
jotto's Avatar
jotto
Not 100% sure but would probably say no. You would have to remove all the 75 safety impact bits and sort out mountings for the chrome bumpers.
Can it be done, Yes. Can it be done easily...no.
Old Oct 15, 2010 | 04:36 PM
stpman's Avatar
stpman
The last 18"-24" has to be changed to the 72 frame section, you might have to re-work the front as well
Old Oct 15, 2010 | 10:27 PM
Artsvette73's Avatar
Artsvette73
Back frame rails and crossmember will need some surgery
Old Oct 16, 2010 | 05:32 AM
58impala's Avatar
58impala
Thanks guys, the cosmetic changes I can probably get round, as long as the main mounting bolts are the same I'll go ahead with it. Anyone know if they're different? Thanks
Old Oct 16, 2010 | 05:53 AM
jotto's Avatar
jotto
Do you have an early frame you can cut up?
Also, check this out...69 front and rear on an 82...awesome work!
http://www.digitalcorvettes.com/foru...d.php?t=114209
Old Oct 16, 2010 | 02:19 PM
58impala's Avatar
58impala
No I don't, only my 75 shell.
Old Oct 16, 2010 | 03:19 PM
Artsvette73
No way to mount the rear bumpers as the rails are diffrent
To shell swap
