Bushing kits
Oct 17, 2010 | 09:39 PM
Bushing kits
I am going to start replacing the orignal rubber on my 74. Rear end first. Any recommendations on kits? Rubber vs poly? car is stock L82 and I dont run the car very hard.
Thoughs?
Mike
Oct 17, 2010 | 10:21 PM
I have had energy suspension poly bushings for the past 10 yrs with no issues.
Oct 18, 2010 | 08:35 AM
Platinum Supporting Vendor
Corvette Suspension Bushings
Poly lasts longer, maintains suspension geometry better, and is generally more forgiving to install. Rubber is more correct.
Feel free to call with any questions,
Tom 1-800-962-9632 ext 240.
Oct 18, 2010 | 09:39 AM
St. Jude Donor '09
I changed all mine to Poly and had no problems so far,Ron 80
Oct 18, 2010 | 11:17 AM
i vote poly also
just make sure if you go poly they need to be well greased
Oct 18, 2010 | 11:22 AM
Definitely poly, unless you want you want to keep it "correct".
Oct 18, 2010 | 11:37 AM
I put poly on mine!
Got a great deal from Summit on the whole kit (I did the front and it included bushing for the rear too).
Oct 18, 2010 | 09:15 PM
Bushings
Poly it is !
Oct 18, 2010 | 10:57 PM
St. Jude Donor '14-'15-'16
Quote:
Originally Posted by
sfallison
I put poly on mine!
I just bought the same complete kit from Summit, they were from $20 to $50 cheaper than all the other forum vendors advertised prices.
Oct 18, 2010 | 11:52 PM
St. Jude Donor '17
How much of a job is the replacement of all bushings?
Oct 19, 2010 | 09:14 AM
St. Jude Donor '09
Most are pretty easy , the control arms are a little hard, but the rest is not too bad. Ron
