Sticky Steering Wheel
Old Oct 20, 2010 | 06:25 PM
Lee C's Avatar
Lee C
Default Sticky Steering Wheel
I have a wheel of a C3 around 75 I guess Been sitting in a drawer in the house for about 20 years.What can be the cause of it feeling sticky tacky and is there a fix Thanks
Old Oct 20, 2010 | 08:49 PM
72LS1Vette's Avatar
72LS1Vette
Try using some Lacquer thinner on the wheel and see what comes off. I had (have) sticky parts all over the interior of the 72 and I'm guessing that it is due to a combination of ArmorAll and smoke/dirt. Simple Green doesn't touch it but thinner cleans it off after several applications.
Rick B.
71406's Avatar
71406
Mine did the same thing. Not sure why. If i recall i used a diluted solution of simple green. I use that stuff for everything.
Old Oct 20, 2010 | 09:17 PM
stevelischynsky's Avatar
stevelischynsky
There was a thread on this about a year ago. This seems to be a common problem with no difinitive solution. This is a result of plastic volitiles leaching out of the plastic. The best the thread could come up with was to mask it with Armoural or some other plastic type cleaner. Even then it is only a temporary solution.
Old Oct 20, 2010 | 10:03 PM
Skip Burney's Avatar
Skip Burney
Mine was really bad, someone had put some kind of cover on it and it was just terrible. I used a clean rag with some MEK and lightly went over the wheen and it is clean as new now.
Old Oct 20, 2010 | 10:16 PM
Lee C's Avatar
Lee C
Thank you everyone
Old Oct 20, 2010 | 11:06 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I have read here that lanolin works without drying out the wheel
Old Oct 23, 2010 | 06:54 PM
Lee C's Avatar
Lee C
Tried the Armour all and it seemed to work Put it on Kijiji sold it for $80 Thanks to all
Old Oct 23, 2010 | 07:42 PM
gingerbreadman1977's Avatar
gingerbreadman1977
that will be the most sticky $80 he will ever spend..the sticky will come back in a few weeks like steve said
Old Oct 24, 2010 | 12:25 AM
Lee C's Avatar
Lee C
I told the guy before he bought it Hope it works out for the dude
Old Dec 12, 2010 | 02:17 AM
vette848's Avatar
vette848
5th Gear
What is MEK.Thanks
Old Dec 12, 2010 | 02:44 AM
TimAT's Avatar
TimAT
Originally Posted by vette848
What is MEK.Thanks
Methyl-Ethyl-Ketone
Bad azz stuff. Cleans anything, dilutes paint, softens plastic, causes liver damage and is absorbed thru skin. Really works great.
Old Dec 12, 2010 | 02:48 AM
vette848's Avatar
vette848
5th Gear
Originally Posted by TimAT
Methyl-Ethyl-Ketone
Once it's dry and cleaned, all the hazzards are gone,right?....
Old Dec 12, 2010 | 08:37 AM
Artsvette73's Avatar
Artsvette73
This was pretty normal back in the day with GM steering wheels. What ever you do, it will come back
Old Dec 12, 2010 | 10:17 AM
TimAT's Avatar
TimAT
Yep. But plastic may stay soft.
Old Dec 12, 2010 | 10:21 AM
U17's Avatar
U17
I've used Windex,ArmorAll ,Simple Green ... Like everyone say's "It comes back".. Good excuse to clean the wheel though....
Old Dec 12, 2010 | 03:43 PM
Big Block 69's Avatar
Big Block 69
The guys who said "It WILL come back" are correct.
Warm soapy water has always worked well for me.
Until next time it sits for a while and needs to be cleaned again.
To Sticky Steering Wheel
Old Dec 12, 2010 | 03:53 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Forget the sticky steering wheel..........the door panel pull handles are the worst.
I tried Fast Orange and it works..... a little bit. The handles are now dull and slightly sticky.
Do the reporduction handles do the same thing? It will be worth buying new ones.
Old Dec 12, 2010 | 08:10 PM
U17's Avatar
U17
Maybe it's just grease and goo from decades of us working on the cars !!!!
Old Dec 12, 2010 | 08:33 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
My '77's wheel is sticky but I'm quite sure it's leather!
