69 tilt/tele steering column
Old Oct 20, 2010 | 07:18 PM
shmoky's Avatar
shmoky
Default 69 tilt/tele steering column
Would a 69 tilt/tele steering column fit in a 68? If so how difficult and what modifying would be necessary? I don't really need the tele but don't think there is just a tilt is there? Correct me if I'm wrong!! Also what other year would fit in a 68?
shmoky
Old Oct 21, 2010 | 05:26 PM
Jim Shea's Avatar
Jim Shea
A 1969 Corvette steering column (T&T or standard non-adjustable) will not just bolt into a 1968. The spacing of the vertical bolts that go through the aluminum breakaway capsules and hold it up into the dash are not even close. Also I don't believe that the cutout in the instrument cluster is the correct diameter to accept the steering column jacket and the shroud that is part of the 1969 column.
One other problem is that the 1969 column has the ignition lock cylinder built into the head. Your ignition lock cylinder and ignition switch are built into the instrument cluster.
The 1968 Corvette dash structure and first generation, energy absorbing, steering column were designed to function together in a serious frontal crash. The steering column jacket was designed to absorb energy while other parts of the column were designed to collapse at the same time.
The 1969 Corvette dash structure and steering column (although similar) had to be redesigned to accept the new, second generation, function locking, energy absorbing steering column with the ignition switch mounted on top of the column jacket under the dash. Also energy absorbing and collapse criteria had to be met with the new dash structure.
Nothing is impossible, but this is not a job to be taken lightly.
Jim
Old Oct 21, 2010 | 11:27 PM
1Fordman's Avatar
1Fordman
shmoky
Ididit makes a 68 only tilt only column that bolts right in and works great.
Old Oct 23, 2010 | 11:06 AM
shmoky's Avatar
shmoky
Thanx for the replies. I was hoping you would answer Jim and I assumed it wouldn't be an easy project. Thanx for the confirmation. 1Fordman I will do a search for that Ididit column.
shmoky
Old Oct 23, 2010 | 01:19 PM
Jim Shea's Avatar
Jim Shea
Default Aftermarket Steering Columns
PM sent
Jim
To 69 tilt/tele steering column
