Door panel Plastic
Old Oct 26, 2010 | 10:19 AM
bartrek's Avatar
bartrek
Default Door panel Plastic
Does anyone know what type of [lastic or foam material is used on the back of door panels? I have a few broken pieces and a couple of bent places I'd like to repair if possible. Don't know what glue/epoxy to use to restore the integrity of the panels. The outer panels are in great shape, so I'm not looking to replace.
Old Oct 26, 2010 | 10:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Original panels have pressure molded paper backs over which the vinyl skin is bonded.
Aftermarket replacement panels often have ABS plastic backs.
Old Oct 27, 2010 | 08:25 AM
78anniversary's Avatar
78anniversary
I just repaired several cracks in the foam/plastic backs of my 78 door panels. Used a 2 part epoxy that was meant for plastic that i bought at Ace Hardware. It worked great.
To Door panel Plastic
