Frogtape?
Old Oct 27, 2010 | 05:20 PM
udornf4's Avatar
udornf4
Default Frogtape?
I bought some Frogtape (the newer GREEN masking tape) that is supposed to be superior for minimum paint bleed.
I've never used it before - Now I'm reading the label and it says it is for "latex" paint!
Anyone have experience using this with spray enamel?
Or should I just take it back and use regular masking tape
Old Oct 27, 2010 | 08:00 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I think it will work ok but just won't seal to it's full potential. The water in the latex activates some kind of gel in the tape and makes it seal along the edges. I've used it around the house and it does do a nice job with latex.
Old Oct 28, 2010 | 07:42 AM
straub18045's Avatar
straub18045
frog tape also has a yellow color, this has minimal adheasion very gentle on surfaces and works good too
Old Oct 28, 2010 | 08:58 AM
earthquake68's Avatar
earthquake68
Well, I bought the green tape I use at the auto body supply place. That stuff never gave me any grief and all I shoot is urethane. You should be fine.
Old Oct 28, 2010 | 09:03 AM
noonie's Avatar
noonie
You will be fine if you use pretty well any real 3M product.
Big difference than the discount store stuff.
The blue is basically a "homeowner grade" with less adhesion and greater sunlight protection on the adhesive. I wouldn't use it.
Here is some good info from 3M
http://multimedia.3m.com/mws/mediawe...PbsQPbPPPPPP--
Old Oct 29, 2010 | 03:49 PM
Mike Culpepper's Avatar
Mike Culpepper
I used it to outline a red border when I epoxy coated my garage floor. It worked very well and came up quite easily, but the Wolverine epoxy coating I used is incredibly thick compared to paint.
Old Oct 29, 2010 | 04:05 PM
Kipring's Avatar
Kipring
I can attest that stuff works great... with latex paint.
To Frogtape?
