Engine size matters
Old Oct 28, 2010 | 07:43 PM
Ironman Motorsports's Avatar
Ironman Motorsports
Default Engine size matters
I'm wantin to pull the original 350 out of my '77 and replace it with something with a few more ponys. If I do, the original is gettin cleaned up and put on engine stand. I'm weighing my options on what to replace it with. For those of you that have replaced the engine in your car what did you end up going with?
Old Oct 28, 2010 | 07:47 PM
straub18045's Avatar
straub18045
pulled my original and put a 385 stroker in, if had to do it again, best bang for buck 406 baby. careful one thing leads to another and next thing you no you maxed your credit cards and your bank account is dry.
Old Oct 28, 2010 | 07:53 PM
Gordonm's Avatar
Gordonm
The is no replacement for displacement. Cubes = more power. More power = more broken parts. You will start to need to upgrade everything from the motor on back to the tires. Your budget will determine a lot.
Old Oct 28, 2010 | 07:57 PM
C3 Stroker's Avatar
C3 Stroker
When the original engine went kaput, I replaced it with a 427 stroker small block....wanted more horsepower. As noted above, the amount of horsepower you buy is inversely proportional to your bank account balance.
Old Oct 28, 2010 | 08:00 PM
Ironman Motorsports
I'm used to 406, 415, and 421's from my circle track days and played with the idea of putting a 421 in it
Old Oct 28, 2010 | 08:19 PM
Corvette.Lover's Avatar
Corvette.Lover
406 Baby!
Old Oct 30, 2010 | 09:16 AM
markdtn's Avatar
markdtn
LSx swap
Old Oct 30, 2010 | 12:41 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Replaced my '78 SA's L82 with a 427 BB ~30 years ago.
Old Oct 31, 2010 | 10:09 AM
U17's Avatar
U17
ZZ383 and 700R4 ... 425hp, 450 tq ...in my '76
Old Oct 31, 2010 | 10:18 AM
dmeesq's Avatar
dmeesq
Worked my 350, bored .030 over, forged flat tops, aluminum heads, roller rockers, 800 cfm carb. RPM air gap intake. ect ect. Now I got a 355 with 425 hp and even LESS weight. Works for me.
Old Oct 31, 2010 | 03:03 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You can make some nice streetable power from a 350ci for peanuts. I made 300RWHP 330RWT with my 355ci. Of course that is never enough and I built a 550HP 406ci and now have a 600+HP 427ci small block which should keep me happy for another year or so
Old Oct 31, 2010 | 06:04 PM
mtcraigco's Avatar
mtcraigco
Big Block, HO454 short block with ZZ502 heads and cam, Edelbrock RPM air gap intake (forget the stock hood)
March makes a pulley/bracket kit that works slick and looks HOT!
Old Oct 31, 2010 | 06:15 PM
jordan89's Avatar
jordan89
Originally Posted by markdtn
LSx swap
To Engine size matters
