C3 Corvette engine ID
Old Nov 1, 2010 | 01:57 PM
rgpta's Avatar
rgpta
Default C3 Corvette engine ID
Can someone tell me what the follwoing engine ID represents:
VD8100HT, VIN 16N597596
I am either going to rebuild or replace depending on what type of engine this is. I believe it is a camaro engine
Old Nov 1, 2010 | 02:46 PM
Peeps9823's Avatar
Peeps9823
The info off the block isn't ringing any bells. Usually the Engine code is Assembly Plant (V=Flint, MI), Month(MM), Day (DD), then code (2 digit for pre 1970). I know HT is a 69 Camaro Code. The 6 in the VIN isn't making any sense. The 1 = chevrolet. And the 2nd digit is the year. The first camaro was in 67, so that digit should be a 7,8, or 9. the N would = Norwood Ohio, and the assembly numbers started at 500,000 for 69. It follows suit for a 69...is the 6 a typo?
Old Nov 1, 2010 | 03:35 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
i'm guessing the "6" could be a mis-read of an "8" digit, but the OP would need to verify that
Old Nov 2, 2010 | 04:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Possibly Camaro. I think the N in the VIN derivitive is the plant code for Norwood. They built Camaros there.
Old Nov 2, 2010 | 04:47 PM
twinpack's Avatar
twinpack
Default code
The HT is for 327/350 HP
Old Nov 2, 2010 | 05:43 PM
Mike Ward's Avatar
Mike Ward
It's probably CHT and not 0HT.
'76 Camaro built in Norwood.
CHT: 350ci, LM-1 350 V-8 4.00 x 3.48 165hp @ 3800 260 @ 2400 8.5:1 4V
To C3 Corvette engine ID
