1981 Motor Specification Help
Old Nov 2, 2010 | 08:44 AM
amf133's Avatar
amf133
Default 1981 Motor Specification Help
I need to know the specification of a 1981 corvette motor. If anyone knows the following please let me know.
Thank You
amf133
Valve spring: outside diameter, tension, and height
Camshaft:
Intake Duration at 050 inch Lift
Exhaust Duration at 050 inch Lift
Advertised Intake Duration
Advertised Exhaust Duration
Advertised Duration
Intake Valve Lift with Factory Rocker Arm Ratio
Exhaust Valve Lift with Factory Rocker Arm Ratio
Valve:
Valve Head Diameter (in or mm)
Overall Valve Length (in or mm)
Valve Stem Diameter (in or mm)
Valve Tip Length (in or mm)
Pushrod:
Length (in or mm)
Piston:
Bore (in or mm)
Engine Stroke (in)
Compression Ratio
Piston Head Volume (cc)
and any other specs you can think of.
Thank You
Old Nov 2, 2010 | 03:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Hook up with these folks.
http://www.l81vetteregistry.com/
Old Nov 2, 2010 | 04:51 PM
mooneyd's Avatar
mooneyd
This may help: http://www.corvetteactioncenter.com/...1/81specs.html
To 1981 Motor Specification Help
