Power Window Relay 79
Old Nov 3, 2010 | 12:56 PM
jamesabarnes's Avatar
jamesabarnes
Cruising
Default Power Window Relay 79
In my AIM the relay found in the consol is called the Alarm Relay but at Wilcox the same relay is called the power window relay. Does anybody know which it is and were I can find one? Does this relay cross referance to another car?
Old Nov 3, 2010 | 01:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For the 79s, power windows were optional. The relay might mount under the console as shown in the AIM. The theft alarm was standard equipment and it's relay might also be under the console.
Call Willcox, tell them what you need, and they'll fix you up with the correct relay.
Old Nov 3, 2010 | 02:02 PM
...Roger...'s Avatar
...Roger...
79 doesn't use a relay for the power windows , only a 30 amp breaker.
Old Nov 3, 2010 | 06:10 PM
jamesabarnes
Cruising
Thanks for the info. I am working on the doors and I don't have 12 volts at th power lock or windows. I thought it might be the relay but maybe not. electrical is not my strong suit.
Old Nov 3, 2010 | 06:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The last year for the power window relay was 1978.
I have a schematic on the site, let me see if I can turn on the line and post it for you.
Willcox
Old Nov 3, 2010 | 07:03 PM
0Willcox Corvette
Former Vendor
This is a 1980 schematic, it should be close enough to get you there.
Old Nov 4, 2010 | 09:35 AM
jamesabarnes
Cruising
Thanks for the schematic I am looking for the relay for the Alarm. Also I have seen the switch for the alarm on other cars in the fender. My 79 does not have that switch nor can I find a switch any where in the car. I know that this may seem like a dumb question but I need to know where the switch is located on the 79. I am biulding this car from the ground up and it is my first rebiuld.
Old Nov 4, 2010 | 09:47 AM
...Roger...
Do yourself a big favor and buy the AIM on disc that Willcox has on his site.
Old Nov 4, 2010 | 11:26 AM
gbvette62's Avatar
gbvette62
The alarm switch is incorporated into your drivers side door lock. The system can only be armed by locking the drivers door with the key, and disarmed by using the key to unlock it.
77-80 use the same anti-theft relay. They sell for about $50 and should be available from most Corvette parts vendors.
Old Nov 4, 2010 | 07:36 PM
0Willcox Corvette
Former Vendor
http://willcoxcorvette.com/product_i...ducts_id=26943 Here is the link to the relay if you need it.
The anti theft relay is mounted in the shift console on the metal upright support... On the rear driver side of it. If you remove the shift console side panel on the drivers side you will see it! Gb nailed it too! The only switch on the 1979 was the attached to the driver side door lock. On later cars there was a switch on both door locks. Late 77 to 79 it was only the drivers side.
I have a picture of the lock and switch, but not on this machine... Sorry... I'll check later when I get home.
Willcox
Old Nov 4, 2010 | 09:30 PM
0Willcox Corvette
Former Vendor
Old Nov 8, 2010 | 12:42 PM
jamesabarnes
Cruising
Thanks for the info, it has been a great help.
Thanks again,
Jim
To Power Window Relay 79
