water pump problem
Old Nov 5, 2010 | 11:12 PM
justin_heat05's Avatar
justin_heat05
Default water pump problem
Ive got a 1979 l48 corvette. I ended up with a aluminum high polished water pump off of another 350 engine and i installed it onto my car. Now my pulleys don't line up. The new one has the pulley farther away from the pump than my original one. What pulley do i need for my water pump to work on my car?
Old Nov 5, 2010 | 11:43 PM
Ironcross's Avatar
Ironcross
It may be the wrong water pump...If your aware of it Corvettes use the short pump...line the new one up against the old and this may be the answer...
Old Nov 6, 2010 | 12:37 AM
FedorC3's Avatar
FedorC3
I just went though this whole problem on my '80 L48! Not sure if you can get a new pulley, but you do have the wrong pump. The pump i had didn't have enough clearance for the pulley. I ended up getting a Stewart pump and it was a perfect fit!
Old Nov 6, 2010 | 04:21 PM
justin_heat05
ive seen some on ebay that have deeper pulleys for my model, i figured you could buy one to make up the difference.
To water pump problem
