differentials between square bore and spread bore
Old Nov 6, 2010 | 10:21 AM
Basfdavid's Avatar
Basfdavid
Default differentials between square bore and spread bore
Good friends tell me that someone would know the difference between these two systems, carburetor, I have seen some intake manifolds accept each other or both, but ... You can install such a spread bore in an intake manifold that will accept?
Thanks for the info
Old Nov 6, 2010 | 10:32 AM
GD70's Avatar
GD70
Square bore means all 4 openings, primary and secondary, on the carb to let fuel & air are the same diameter. Spread bore is the two primary bore diameter is smaller then the secondary bore diameter.
Regarding manifolds, some except both type of carbs, others are specific to the type of carb.
Old Nov 6, 2010 | 11:04 AM
Basfdavid's Avatar
Basfdavid
thank you very much and I understood what the differences are, my question is the intake manifold are two holes, means that accept square bore and spread bore?
Old Nov 6, 2010 | 12:39 PM
Roughrider's Avatar
Roughrider
Yes...that's for both square and spread bore carbs.
Old Nov 6, 2010 | 12:52 PM
Basfdavid's Avatar
Basfdavid
thanks friend :P
Old Nov 6, 2010 | 12:59 PM
SteveG75's Avatar
SteveG75
Not really.
That manifold has two sets of bolt holes because Holley and Carter carbs (which are both square bore) have different bolt patterns. If you bolt a spreadbore carb (Q-Jet) to that manifold, the secondary thottle plates will hit the sides of the opening. You would need an adapter plate to make it work.
Here is a spreadbore manifold. Note where the opening is in relation to the bolt holes.
Old Nov 6, 2010 | 01:54 PM
highschool67's Avatar
highschool67
Originally Posted by SteveG75
Not really.
The manifold you show is square bore only. The extra bolts holes are for the different configuration of square bores you can put on. ie: Holley and Edelbrock. The Edelbrock square bore Carter copy uses the other bolt holes as does a carburetor adapter.
To differentials between square bore and spread bore
