switch under steering column
Old Nov 10, 2010 | 10:41 AM
onionhead's Avatar
onionhead
Default switch under steering column
hey guys,
I have a switch that was attached under the steering column in my '76.it has 2 vacuum lines attatched to it.what is this for? thanks for any help
Old Nov 10, 2010 | 10:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Headlight override. It allows you to open the headlight doors a time or two with the engine off.
Do you have an owner's manual for your 76? Lots of useful information in the owner's manual.
Old Nov 10, 2010 | 02:18 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
yup, what he said, lol! the original intent was to be able to raise the headlamps without the engine running from the vacuum reserve tank.
Old Nov 10, 2010 | 08:11 PM
shrekviper's Avatar
shrekviper
It's also meant to keep the headlights open w/o the lights being on to avoid freezing them closed in the winter.
To switch under steering column
