Door panel adhesive
Old Nov 16, 2010 | 12:19 PM
kapla74's Avatar
kapla74
Default Door panel adhesive
My drivers side door panel is separating from the door metal frame...what can I use prevent it to continue? What adhesive will give the best bond' and how do I need to prep the area..do I need to remove the whole thing and can I just add the adehsive to the affected area and C-clamp it until it cures?
Thanks in advance for any tip...
Old Nov 16, 2010 | 12:49 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do not attempt to remove the door skin. Leave well enough alone.
Fusor or similar will rebond the skin. Clean the road gook out of the open area as best you can.
Old Nov 16, 2010 | 02:10 PM
kapla74's Avatar
kapla74
Mike what kind of adhesive is the Furor stuff? can´t find it..I need to know its base so I can match it to similar product down here!!!
Again Thanks!!!
Old Nov 16, 2010 | 03:30 PM
oldsarge's Avatar
oldsarge
I have used "3M Structural Adhesive" on a few panels to metal. It is a two part mixture, and you have to work fast, seems to work well.
Old Nov 16, 2010 | 04:34 PM
kapla74's Avatar
kapla74
I´ll do some search here..and let you guys know how it turned out!!!
again thanks...
Old Nov 16, 2010 | 04:44 PM
champs65's Avatar
champs65
The fiberglass to metal fusor product is fusor 127. It is a 2 part epoxy that mixes itself with a twin cartridge gun and disposable nozzle. Excellent stuff; have used it before. I think they also make faster setting versions of 127 as well.
If you want to research it and find a comparable product there, here's the site:
http://www.lord.com/Products-And-Sol...roduct.xml/310
Old Nov 16, 2010 | 04:53 PM
kapla74's Avatar
kapla74
I´ll check in a autobody supply..
To Door panel adhesive
