Quick body shim question.....
Old Nov 18, 2010 | 03:02 PM
razman's Avatar
razman
Default Quick body shim question.....
gettin ready to put the body back on my 68' restoration project. i don't have the luxury of knowing how many shims the body originally had, as i purchased this car already in pieces. i plan on just shimming as needed, to get the body to sit level, based on wheel well measurements from each side.....my question is this:
what are the fewest shims you guys have seen, and what are the most shims that have been recorded? is it possible to have a mount with no shims at all? thanks!! Rick
Old Nov 18, 2010 | 03:23 PM
oldsarge's Avatar
oldsarge
At different mounting points, I have seen as little as none and 5 at the most. The body will sit differently for almost any frame to body drop.
Old Nov 18, 2010 | 04:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I've seen zero and four. And, yes, it is entirely possible to have a mount with no shims.
Old Nov 18, 2010 | 04:50 PM
Mike Ward's Avatar
Mike Ward
What they said............
Old Nov 18, 2010 | 05:05 PM
razman's Avatar
razman
thank you very much!! operation body drop is ON.
Old Nov 18, 2010 | 07:14 PM
LT-1 kid's Avatar
LT-1 kid
I droped my 69 body 3 weeks ago and used 3 shims total, 5 have no shims at all.
To Quick body shim question.....
