Astro Tops - T top replacements?
Old Nov 28, 2010 | 11:29 PM
samsonb's Avatar
samsonb
Originally Posted by 76vette1
I bought a one piece Astro top for my 76. It squeaked and rattled and did not seal at all. I attribute these problems to a very large acrylic top with no structural strength. The T-tops may be better, but these acrylic tops scratch easily and will not look good in a short period of time.
The Astro Top will scratch easily as they don't put a hard coating on the lense like other acrylic top manufacturers. Just dragging a car cover over it will scratch it. The Astro Top would probably scratch from just breathing on it.
Though in general, acrylic tops will scratch more easily than say glass. If your car has T-tops, I'd stick with T-tops vs. a single piece of acrylic that can crack.
Astro Top also has a bad history of their lense coming unglued from the frame on the C4 tops. Not sure about the C3 tops they do. On my C4, I found one day over half of the top was unglued. Mr. Thompson at Astro Top didn't seem to care and wouldn't tell me what glue they used so I could get the lense reglued.
You are liable if the lense flys off and hits something or possibly kills someone.
Old Nov 29, 2010 | 12:22 PM
Fast81's Avatar
Fast81
Had a 1-piece on Fast 81 for 10 yrs now. Looks new
Liked the xtra 2-3" headroom, and ALOT lighter than glass.
YRMV
Old May 25, 2012 | 08:05 PM
hockey30's Avatar
hockey30
Just purchased a Astro Top for my 1980 Corvette. I had to contact Customer Service because the installation instruction did not come with top. They Email me the instruction the next day. Installed top and had no problems. Really like the looks and it seals lot better than my T-tops did. I order the top from them direct for $399.00..... Shipping $90.00..... Top storage bag $40.00. Cost was a lot cheaper than buying new T-Top. Would buy from them again.
Old May 26, 2012 | 07:10 AM
KenSny's Avatar
KenSny
I bought one in 1998 for my 1975 when one of my T-Tops had a broken pin area and a large crack in the fiberglass.
Picked up a used T-Top at Carlise in 2000 and sold the Astro top to a forum member in 2000.
Although it fit good, no water leaks, and lots more headroom, it SQUEAKED a lot! I'd never get another Astro top again.
Old May 26, 2012 | 07:41 AM
540 vette's Avatar
540 vette
I had a astro top one piece on a 77 I had. No problems.
I just bought one for my 80, looks great no problems with it. Also no problems with them answering the phone.
You have to remember you are paying $400 for it. You will pay upwards of $1000 for factory glass. So it may seem a little cheap looking. But it is fine and fits as good as the t roofs.
Old May 26, 2012 | 09:39 AM
srosa75's Avatar
srosa75
Originally Posted by TPI BOY
I have one on my 75 and haven't had any
problems I put foam inside the weather striping
and it seals much better
Tpi boy, please check your pm
Old May 26, 2012 | 10:22 AM
TPI BOY's Avatar
TPI BOY
Default no pm
Sorry I don't bave any new pm's
Old May 26, 2012 | 08:55 PM
texasbaehr's Avatar
texasbaehr
Default Astro Tops
Originally Posted by chrisd0729
Anyone use these guys or know anything about their quality? My '80 is more of a driver and doesn't need factory original glass and I need to fix a cracked passenger side mirrored top. Price doesn't look bad but, want to hear from someone who has used them before trying them.
http://www.astrotops.com/gmtops.html#
Thanks,
They will also rebuild your existing glass tee tops with acrylic instead of Glass for $699 plus your cores. Cuts about 15 lbs of weight and you have a choice of colors. This beats $1200 for a new set of Glass tops that will crack again.
I personally don't like the one piece top. The mounting system requires a screw drive to install and remove and the mounts are big blocks of clear acrylic glued to the underside of the top. It is well made and secure but not my thing. I would go for the acrylic T-tops. They look stock and retain the factory frame and mounting system.
Old May 26, 2012 | 09:22 PM
TPI BOY's Avatar
TPI BOY
If the top squeaks just put some weather strip jell on the
weather strip front and back, then make sure everything
is tight
Old May 26, 2012 | 10:21 PM
texasbaehr's Avatar
texasbaehr
Default Correction
Correction, $519 with core for Smoke and Bronze, $50 extra for blue.Add $250 with no core.
Old May 31, 2012 | 07:03 AM
srosa75's Avatar
srosa75
I didn't want to hijack the thread, but.....
How and where did you put foam in the weatherstripping?
Old May 31, 2012 | 09:23 AM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
The shop is located in Florence, Alabama. I live about 15 miles from him and have been a customer for several years. He has just about every top you could want. I personally have bought 3 tops from him and will be buying a set for my 73 project when I get to that point. The tops I have bought were two for a C5, a smoke gray and a solid black. Both are perfect with no leaks and no whistling. The other was a one piece for my 81 and it works great. If you can get to his shop to buy the tops he will fit and adjust them for you at no charge. If there is any way that I can help just let me know.
Old May 31, 2012 | 09:52 AM
  #33
76_Stingray's Avatar
76_Stingray
Originally Posted by HamadUP
one word : EXPENSIVE!
Anything "Corvette" will be expensive. We all should know this by now
Old May 31, 2012 | 11:56 AM
  #34
Snoopysvet's Avatar
Snoopysvet
How to the Astro Tops stow in the back, any pictures?
Old May 31, 2012 | 03:10 PM
  #35
TPI BOY's Avatar
TPI BOY
I put the foamin the 2 side pcs so yhe windows would seal
good when closed.
Old Jun 30, 2012 | 02:38 PM
  #36
bobs76stingray's Avatar
bobs76stingray
Yea,I just saw a set of Blue glass T-Tops for 3600.00,Now thats expensive.This is a real good price.Everything costs more now days!
Old Jul 1, 2012 | 09:39 AM
  #37
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by BPHORSEGUY
...Anyone know what the slight mod is for '68-'77...
78-82 tops have one latch at each front corner and a tongue which slps into a receiver on the halo panel. The halo panel connector ties the tops to the factory alarem system.
68-77 tops have two latches and use different hardware on the halo panel. The tops are not part of the alarm system.
Swapping either for the other will require the appropriate hardware on the halo panel.
Old Nov 3, 2015 | 12:23 AM
  #38
antoniov1's Avatar
antoniov1
Hey how did you connect the back screws mine looks like this and also what did you mean you put foam inside the weatherstripping? Can I get a pic please
Old Nov 3, 2015 | 12:27 AM
  #39
antoniov1's Avatar
antoniov1
How did you connect the back part of the t top? Mine looks like this... And doesn't seem right...
