Who Does Your Exhaust System Work?
Old Nov 28, 2010 | 11:14 AM
LancePearson's Avatar
LancePearson
Default Who Does Your Exhaust System Work?
If you don't do it yourself who do you use to put new exhaust manifolds and a new exhaust system on your car? 2011 thing for me. One Ram's Horn will be replaced, cracked, and I haven't decided yet between 2-1-2 with high flow cat converter or straight duals.
Lance Pearson
Chester, Va.
Old Nov 28, 2010 | 12:00 PM
fugawi's Avatar
fugawi
go with duals with an x-pipe. you'll get your best power out of that combo.
some guy named fugawi does all my work..
Old Nov 28, 2010 | 01:16 PM
PRNDL's Avatar
PRNDL
You may have to search around in your area for a muffler shop that has experience with performance exhaust and working with older cars. Sometimes you can actually find such a person at your local Midas (or Meineke) shop, but don't count on it. In my case, based on many recommendations, I drove over an hour to take my car to a shop that I knew did quality work.
I think you are on the right track. I wasted a lot of time and money trying to do it myself, ending up with a wobbly clamped system that would hang too low and scrape on the street, flex-hose from the headers, exhaust tips that would regularly get blown off when the car backfired! due to having exhaust leaks. Ahhhh the good ol days!
http://www.mufflex-performance.com/index.html
Old Nov 28, 2010 | 02:25 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
I think I know that guy, he does my work too but I think your spelling it wrong, its fucawi!!!
Old Nov 28, 2010 | 02:59 PM
GD70's Avatar
GD70
An exhaust system is a really easy job to do yourself. It's all nuts & bolts. The only fab work would be if you decide to go with the X pipe that needs to be cut & welded in. Corvette Central has nice, correct fitting systems.
Just a thought.
Glenn
Old Nov 28, 2010 | 03:16 PM
twinpack's Avatar
twinpack
Check out Pypes. They are a supporting vendor here. I just looked a SS system with X pipe as a bolt on system for my "68"
Old Nov 28, 2010 | 04:19 PM
LancePearson
Where does the crossover x pipe deal go...before the first holder where the pipes go through the frame or after?
Old Nov 28, 2010 | 04:22 PM
LancePearson
I saw that on the computer...Corvette Central and Mid AMerica both seem to have "off road systems." Will start searching out a shop that can replace a header and install the pipes and mufflers as well. I think I'd like the duals and get the government's cat. converter out of there.
Old Nov 28, 2010 | 06:01 PM
terry82's Avatar
terry82
open the cat up .put it back on for looks.you never no who would want to take a look.
Old Nov 28, 2010 | 06:07 PM
PRNDL's Avatar
PRNDL
Where is this guy named fugawi? Or, in short form:
Where the fugawi?
To Who Does Your Exhaust System Work?
