unknown part under dash
It almost looks like the wires my stock alarm has.
yellow and dark green go to the brake lights....
red = power
white is usually courtesy lights?
and black grounds
except I just ripped out my interior on my 69 and found the alarm flasher in the rear storage compartment but definitely didn't have one of those like you did....
The signal, now converted to mechanical energy, is sent out on the spring where it is picked up by the "receiver" transducer.
The receiver turns this mechanical energy back into a signal that is sent out to a second amplifier and an additional speaker usually mounted in the rear. Other units (e.g., guitar amps) can mix this delayed signal back into the main signal and feed it to the regular amp to obtain reverb.
When the signal passes through the springs, a portion reaches the end and is reflected back toward the transmitter side, then back to the receiver side, ad infinitum, creating further delays that goes on until there is no signal left in the springs. This creates reverberation.
The most common point of failure on reverb spring units is the transducers.
A modern reverb spring can:
I try to connect the part at one time and find out the sound.
I´ll post the result.
Thanks Uli
Definitely not factory..
