A/C blockoff plate
Old Dec 16, 2010 | 11:28 AM
BryanB75's Avatar
BryanB75
Default A/C blockoff plate
Has anyone removed the A/C unit and blocked off that area? Since I have the motor out now and have no plans to put A/C back in I was to get rid of that big unit and just make/buy a flat panel to cover that area.
Pics are a plus
Old Dec 16, 2010 | 11:36 AM
BryanB75's Avatar
BryanB75
I found 2 threads. One has a Vintage air plate and the other I can't see pics at work (Blocked)
Still searching
Old Dec 16, 2010 | 12:34 PM
BKbroiler's Avatar
BKbroiler
I'm using a block-off plate from acdelete.com. Not cheap, but it works good.
Old Dec 16, 2010 | 12:56 PM
BryanB75's Avatar
BryanB75
Damn...that blower motor is part of that right? $160..ouch
Old Dec 16, 2010 | 01:27 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Yes it is not cheap but it works. Or if you are handy look at the picture of it and look at what you have and make your own from fiberglass. But in the end I am sure you will find the price not that bad after all the work lol.
Old Dec 16, 2010 | 01:52 PM
MyRed69's Avatar
MyRed69
Glassed mine in and will fab a plate for the blower hole.
Old Dec 16, 2010 | 03:08 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Here is what I did.
[/IMG]
Old Dec 16, 2010 | 09:02 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...when I made my old '75 L-82 coupe an A/C delete car(when I installed a 260hp crate motor and changed it over to a four speed car)I bought a nice used engine side non A/C heater core housing and using existing studs on the firewall, bolted it down. I then made a heavy construction paper template of the opening, then cut out an exact piece out of heavy sheetmetal. By the time I sealed and smoothed the edges, painted it and mounted the non A/C heater core cover, very, very few people could even detect what I had done. I even went so far as to install a '72 Corvette non A/C inner heater box, windshield wiper switch non A/C "CORVETTE" script bezel and the correct non A/C heater controls.
...I pretty much sold all the used old(some not useable)A/C pieces for what I had in mint/re-conditioned non A/C pieces.
...I just wished I would have kept that template that I used as quite a few people here could have used it in the last 6 or so years since I had done mine.
Old Dec 16, 2010 | 09:13 PM
SHOWME's Avatar
SHOWME
I'm just using an aluminum plate for now.
Old Dec 16, 2010 | 10:35 PM
johnt365's Avatar
johnt365
I just ordered this one. http://www.acdelete.com/pages/68-82_Y-Body.htm
I havent received it yet so cant comment on the quality yet.
To A/C blockoff plate
