Tempreture switch
Old Dec 18, 2010 | 10:38 PM
BERIN's Avatar
BERIN
Default Tempreture switch
Got a stroked 350 that has auxillary fans. The question is why do i keep blowing out the temp switch that turns on my fans? All it is supposed to do is get to 185 degrees and form a gruond that turns on my fans. It seems that after a month of use it blows out. I know this because once i take the connector off and ground it too the frame it works.
Old Dec 18, 2010 | 10:57 PM
speedreed8's Avatar
speedreed8
is the switch acutally grounding the fan motors themselves?, the switch needs to just ground the coil of a relay , and the relay provides a path to ground for the motors.or supplies +12v to the motors. aftermarket switch wasnt designed to carry the load of the fans.
http://forums.corvetteforum.com/c3-t...spal-fans.html
Old Dec 19, 2010 | 03:50 AM
sly vette's Avatar
sly vette
Must use relay!!!
Old Dec 20, 2010 | 01:32 AM
BERIN's Avatar
BERIN
Correct it does have a relay and is set up properly.
When the temp switch in the manifold heats up to 185, it forms a ground and through the relay operates the fans. But for some reason i keep burning out the temp switch
Speedreed8 .....i looked at durango boys thread, my fans are hooked up right, but i am operating two fans off of one relay using a 30 amp should i use ahigher amp relay
Old Dec 20, 2010 | 01:40 AM
sly vette's Avatar
sly vette
By blowing out or burning out do you mean that it fails and does not complete the circuit?
Old Dec 20, 2010 | 09:57 AM
longbros's Avatar
longbros
It is possible, that the coil current of the relay you are using is a bit too high for the temperature switch, and after a number of cycles, it burns the switch contacts out. Sometimes, tandem relays are needed, a small coil current relay driven by the temperature switch that then drives a larger relay that actually closes the fan circuit.
In addition, the relay coil will have an inductive kick when the temperature switch opens. If the relay coil current is high or marginal, the repeated inductive kick and arcing as a result, will burn the temperature switch contacts. If this is the case, a capacitor and/or a diode may be needed to supress the inductive kick. Or, just go with the tandem relay set up as mentioned above and it should be fine.
Old Dec 20, 2010 | 10:29 AM
speedreed8's Avatar
speedreed8
i have dual fans on my car, but i have 2 relays, one for each fan, and also i have 2 temperature switches, one for each fan, but one is a 185 & the other is a 195 on.
Old Dec 20, 2010 | 10:55 AM
U17's Avatar
U17
I have two relays.. Now thinking about two switches ...
Old Dec 20, 2010 | 11:34 AM
ajrothm's Avatar
ajrothm
Make sure to have a ground wire from the radiator to the frame or bumper bracket etc on the car. (not that it's causing your problem but....) it will stabilize the grounding circuit and give more consistant activation.
Old Dec 25, 2010 | 12:49 PM
BERIN's Avatar
BERIN
awesome thanks, i should ground my radiator, also going to two relays
Thanks and merry christmas
To Tempreture switch
