Wierd things under my dash...
So today I decided to do all the little things to my vette that I havent been able to do in a while, and I have found a few wierd things under my dash.
first what is this wierd push button thingy? I thought it was a kill switch but it dosnt affect anything on the car. Just hangs there on two black wires.
Also, next to the headlight switch under the dash there is another wierd thing in a bracket that dosnt look stock. Anyone know what this is?
And last but not least, there is the random brown wire with a connector hanging from above the steering column. What does it connect to? Could this why my tach isnt working?? I sure hope so.
#1 Switch could be a reset button. I had one on my TransAm. There was a short that noone could ever find in my reverse mode lights. Everytime I put the car into reverse, the fuse would blow. So the switch was installed so it would blow before the fuse. All I did was press it to reset it. Sounds crazy/stupid but it worked. #2 looks like the trip-milage button or headlight button. #3 I don't know-is there a male plug for it to plug to somewhere?
#1 could be anything.... you'll have to trace back where the wires go to.
#2 is definitely a trip reset ****.
#3 is definitely a wire that goes to a capacitor on the steering column that I believe has something to do with the radio.
I would trace that wire and make sure the alarm components are all removed. I had a car that had half of the alarm still there and one day it decided to activate and would not let the car start.
That was a BAD day, stranded and no clue what to do.
Find and fix,
Frank
Find and fix,
Frank
