72 exhaust tips
Old Dec 29, 2010 | 08:01 AM
riverracer au's Avatar
riverracer au
Default 72 exhaust tips
how far past the bezel should the tips protude?
and which is the correct placement of the pipe tip hole, outer side of the car or inner?
i have seen lots of different setups.
thanks
Old Dec 29, 2010 | 08:34 AM
jnb5101's Avatar
jnb5101
the pipes are to the outside. extend the tips about 1". i used after market tips and had to shorten the inlets of the tips in order to set them in place. i just used a saws-all to cut the length and then cut a notch length-wise so a muffler clamp would compress the tip inlet.
Old Dec 29, 2010 | 10:05 PM
72ls5fla's Avatar
72ls5fla
this video shows how they look.
To 72 exhaust tips
