L68 I think
Old Jan 2, 2011 | 06:43 PM
NBK1974's Avatar
NBK1974
Default L68 I think
Hey guy new vette owner here, I purchased a 1969 L68 I was told today. The Tri power 427 has been gone since 1975, the rear and trans are said to be original. My question is there are all the signs of big block, rear sway bar, 5600 rpm red line, shift plate states 427 400 hp, 427 hood, has over flow on passanger fender. Is this a rare car? The car has all the signs of ac inc astro vent glass, A/C on the vent controls, and the vents in the center of the dash. The car Has no power brakes or Power steering. so It sounds a little odd to me. Car is in good shape with some repairs needed to the rear wheel lips, and new carpet and seat covers. What do you feel a car like this is worth? Thanks for your time
Old Jan 2, 2011 | 06:58 PM
vette54728702's Avatar
vette54728702
It's a shame that the original motor is gone... definately hurts value.
Old Jan 2, 2011 | 08:39 PM
NBK1974's Avatar
NBK1974
Do you think its worth the time to try and track down a 427 l68 motor and tri power or will the value not be worth the money invested?
Old Jan 2, 2011 | 09:38 PM
PRNDL's Avatar
PRNDL
Easiest thing to check for would be whether there is a single fuel line running from the tank up the passenger side of the frame to the fuel pump. If there is a 2nd fuel line (a fuel return line) along the frame then it is very unlikely that the car started life with a tripower setup.
Old Jan 3, 2011 | 11:18 AM
BBCorv70's Avatar
BBCorv70
Locating a 'correct' L68 motor, most likely having to buy all parts and put one together may be quite expensive. I doubt you'd recover the cost in the near future if that's what you're asking. OK if you'd like to make the car 'correct' for your own enjoyment or possibly having it judged. NCRS takes only a minor deduction for an incorrect stamp pad so long as the casting numbers and date codes fit.
Do you have any paperwork proving it was an L68? Tank sheet, p-o-p, invoice, etc?
Is this a coupe or convertible?
Old Jan 3, 2011 | 11:29 AM
Mike Ward's Avatar
Mike Ward
Depends- if when it comes time to sell it and you're truthful that it's not the original motor then you'll be upside down. If you pass it off as being an original to some fool, then you might break even.
Not worth it Enjoy it for what it is, not what it used to be.
Old Jan 3, 2011 | 12:21 PM
longbros's Avatar
longbros
[QUOTE=BBCorv70;1576401215]Do you have any paperwork proving it was an L68? Tank sheet, p-o-p, invoice, etc?QUOTE]
Does the p-o-p indicate the engine option?
Old Jan 3, 2011 | 12:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What's missing? Only the tri-power set up or the original engine? What's in the car now? All '69s had Astro-Ventilation scripts on the door glasses regardless of whether the car had factory air.
Go here http://www.cranescorvette.com/1969_s..._guidebook.htm and see if you can obtain a copy of the 1969 Guidebook. Good reading.
Old Jan 3, 2011 | 01:49 PM
BBCorv70's Avatar
BBCorv70
[QUOTE=longbros;1576401815]
I was referring to the Protect-O-Plate which would verify the original configuration was L68.
I'm pretty sure the P-O-P shows the engine option though I've never studied one...
Old Jan 3, 2011 | 01:52 PM
BBCorv70's Avatar
BBCorv70
If the owner wants to build it as an L68 I'd say go for it. Just need to realize it's unlikely he'll get the price of an 'original' L68 when it comes time to sell. It's now a NOM...
Old Jan 3, 2011 | 01:55 PM
longbros's Avatar
longbros
[QUOTE=BBCorv70;1576402822]
That was my question, would the Protect-O-Plate indicate the original configuration, and verify it was originally an L68? I know a tank sticker would.
Old Jan 3, 2011 | 02:12 PM
Easy Mike's Avatar
Easy Mike
...That was my question, would the Protect-O-Plate indicate the original configuration, and verify it was originally an L68?...
Yes.
Old Jan 3, 2011 | 10:42 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Not without the original motor & tri - power ............
"WAS" would be a more "CORRECT" term............no pun intended
Old Jan 4, 2011 | 07:25 AM
Faster Rat's Avatar
Faster Rat
Yes.
Only if it is the original P-O-P that is stamped at the factory with the codes, then the original owner's name is added using a plastic dymo type of reverse reading tape. I have what is known as a "subsequent owner" P-O-P that the dealership ordered from the factory for the remainder of the 5/50 warranty. It is stamped with the owner's name and only shows that my car had 3400 miles on it...no option codes. The car was evidently used as a demo, or maybe a quick trade-in?
Old Jan 4, 2011 | 09:28 AM
NBK1974's Avatar
NBK1974
Coupe, I found the tank sticker it Is a l68 with ac and posi rear, am/fm radio and alarm. I purchased this car for 6k so I just dont know if I should put it back together and drive it or tear it apart and find a motor? I feel I made a good buy? The trans is matching as is the rear and the car is all original with the exception of a l88 hood which was needed to clear the torker intake and 750DP on the car now.
Old Jan 4, 2011 | 09:30 AM
NBK1974's Avatar
NBK1974
Yes motor is the only thing missing, trans and rear are correct
Old Jan 4, 2011 | 09:33 AM
NBK1974's Avatar
NBK1974
Any one know how I can get a list or registered owners ? I would like to see if I can try to find the guy who pulled the 427 motor out.
To L68 I think
Old Jan 4, 2011 | 02:30 PM
BBCorv70's Avatar
BBCorv70
Some state DMVs may provide a history for a fee. Don't know if they'll divulge former owners names and addresses.
There's a service on the internet which will do the detective work for a fee. I don't recall the name. It was posted a few months ago in another thread. Maybe Alan71 recalls?
Old Jan 4, 2011 | 02:58 PM
razman's Avatar
razman
Well, i would say for 6k you got a pretty good deal now that you have located the tank sticker....i would think it would definitely be worth putting together a matching number engine for this car. good find! what are the original colors?
Old Jan 4, 2011 | 03:25 PM
NBK1974's Avatar
NBK1974
Dayton Yellow with black interior
