drivers side door won't open
Dan
You will have to replace the exterior door handle assembly. Several things to keep in mind: When buying a new door handle assembly, make sure you buy one that is "Made In USA". It will cost more than one made "off-shore" but it's worth it as the cheaper one will break in the same place in about 1 year. (Advise from a local Corvette Restoration place). Read this article http://www.corvettefever.com/howto/4696/index.html Take your time and don't get frustrated, it's a bear of a job and VERY little space to work in. One of the keys to it is to get the lock water shield down and out of the way. Also when moving the retaining clip on the arm that is attached to the clevis on the door handle opening rod, don't push the clip too far so that it comes off the arm because it's a real bear to reinstall (learned that the hard way). To pull the clip back into place I took a piece of stiff wire and bent a hook on the end and got behind the clip and just pulled it back into place. Once you've gotten the new handle installed and hooked up, make sure you try the interior and exterior door locks to see if they operate freely. (don't make the mistake I did and put everything back in place and reinstall the door panel before trying the locks and then have to remove everything again @#$%%) if they don't, you will have to disconnect the clevis from the arm and move the clevis either up or down until the locks work freely. Mine was putting too much downward pressure on the arm and I had to turn the clevis upward. Again, take your time, you WILL skin and cut your fingers and hand in a few places (I'm 70 years old and I used some words that I haven't used since I was in the U.S.Army in the early '60's)
Good Luck, Mike
PS Depending on who you talk to, some will tell you to do it with the window up and some will tell you to do it with the window down. For me, on my '74 it worked the best with the window all the way down.
You will have to replace the exterior door handle assembly. Several things to keep in mind: When buying a new door handle assembly, make sure you buy one that is "Made In USA". It will cost more than one made "off-shore" but it's worth it as the cheaper one will break in the same place in about 1 year. (Advise from a local Corvette Restoration place). Read this article http://www.corvettefever.com/howto/4696/index.html Take your time and don't get frustrated, it's a bear of a job and VERY little space to work in. One of the keys to it is to get the lock water shield down and out of the way. Also when moving the retaining clip on the arm that is attached to the clevis on the door handle opening rod, don't push the clip too far so that it comes off the arm because it's a real bear to reinstall (learned that the hard way). To pull the clip back into place I took a piece of stiff wire and bent a hook on the end and got behind the clip and just pulled it back into place. Once you've gotten the new handle installed and hooked up, make sure you try the interior and exterior door locks to see if they operate freely. (don't make the mistake I did and put everything back in place and reinstall the door panel before trying the locks and then have to remove everything again @#$%%) if they don't, you will have to disconnect the clevis from the arm and move the clevis either up or down until the locks work freely. Mine was putting too much downward pressure on the arm and I had to turn the clevis upward. Again, take you time, you WILL skin and cut your fingers and hand in a few places (I'm 70 years old and I used some words that I haven't used since I was in the U.S.Army in the early '60's)
Good Luck, Mike
Picture looks exactly like mine did a few months ago and I did not enjoy myself changing it. I used the link mentioned.
Just a word of caution. Roll your passenger window down until you do the replacement. If the passenger side handle breaks too then your ......
Good luck.
Thanks again.
Glenn
