427 1969 Suffix LO?
Old Jan 10, 2011 | 02:18 PM
70rs/ss396's Avatar
70rs/ss396
Default 427 1969 Suffix LO?
Hello
I found an short block #512 casting block with the suffix LO. When I check in the lists it should be a 1969 corvette 427 430 hp...Hi Perf.
Can it be an L88?
BUT, when I look above the oilfilter it only has one 1/2 threas output ....and then it is a 2 bolt main? 4 bolt should have two 1/2 holes?
Old Jan 10, 2011 | 02:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The Corvette Black Book lists LO as the suffix code for the L88.
Are you sure the code is not LQ?
What's the VIN derivitive?
longbros's Avatar
longbros
I don't know much about these. Are you sure it is not an LQ? I have seen some LQ blocks that had light stamps and it looked like LO.
Old Jan 10, 2011 | 02:49 PM
longbros's Avatar
longbros
Easy Mike, great minds think alike!
Old Jan 10, 2011 | 03:01 PM
70rs/ss396's Avatar
70rs/ss396
Need to check that out.
Old Jan 10, 2011 | 03:11 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by longbros
...Easy Mike, great minds think alike!...
I resemble that remark...
Originally Posted by 70rs/ss396
...Need to check that out...
Absolutely. Check the pad again.
Old Jan 10, 2011 | 03:36 PM
WESCH's Avatar
WESCH
HI
As mentioned already, it is out of the question that there was a L88 with 2 bolt mains only.
Rgds. Günther
To 427 1969 Suffix LO?
