Battery Tenders
Old Jan 11, 2011 | 08:57 AM
RMVette's Avatar
RMVette
Default Battery Tenders
On my ’70 and my ’98 I have a Battery Tender connected due to both being driven occasionally, the ’70 mainly to car shows and the ’98 monthly. I figured since I had the Battery Tenders connected I wouldn’t have starting issues but over the past 2 months both batteries have died with the Battery Tender showing a green float light. I’m especially torque’d on the ’98 because it’s an AC Delco battery and my first lasted 8 years and this one has lasted only 4 years. Researching I found that one tender has what’s called a “desulfator”…. So the question is….Is that feature important? I’ll bag both my Battery Tenders and purchase new ones if it helps. Or am I out of touch expecting too much longevity of a battery with a tender attached?
Thanks in advance!
Old Jan 11, 2011 | 10:29 AM
garage-ghost's Avatar
garage-ghost
What brand of charger are you using?
Old Jan 11, 2011 | 10:34 AM
RMVette's Avatar
RMVette
Battery Tender Plus.
Old Jan 11, 2011 | 10:46 AM
garage-ghost
I just wondered because I've been using 4 of them for several years now without any problems. I had a battery go dead while on the charger but it was over 10 years old. I keep the car and generator batteries hooked up all the time. I park it I hook it up.
Curious as to what you find.
Old Jan 11, 2011 | 10:56 AM
l1dws's Avatar
l1dws
I had my Delco last only 4 years attached to a battery tender when not running the car. I have a interstate on my 70 that is already 6 years also attached to battery tender plus. Good luck
Old Jan 11, 2011 | 11:15 AM
KTKelly's Avatar
KTKelly
I've got two of these and they seem to get the job done.
http://www.northerntool.com/shop/too...2045_200422045
One for my JD riding mower is a couple years old, the other is in it's first year on the Vette.
Old Jan 11, 2011 | 11:19 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Go with a C-Tek 3300. They are the best battery tenders in the industry IMO. I use them on my Corvettes old and new. It has the desulfator design to keep down sulfur buildup which kills batteries. I have used many over the years and really like these alot
Old Jan 11, 2011 | 11:21 AM
RMVette's Avatar
RMVette
Will the C-Tek bring an old battery back to life if it has the sulfur buildup? Their tech data says so...true/false in real life?
Old Jan 11, 2011 | 12:18 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I use C-tecks on everything I own I have 4 of them and they are great, 3300 is the model, but not sure if it will bring back a dead batt. Ron
Old Jan 11, 2011 | 01:41 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
False. They are more for the maintenance of a good battery. I would start with a new battery, hook it up to the C-Tek and your battery issues are over.
Old Jan 11, 2011 | 03:21 PM
Vette5.5's Avatar
Vette5.5
I also own two Ctek's, and batteries seem to last forever on these thing's. Xtreme also has the technology, but a bit pricier. These wont give you a green light unless the battery's truely charged. If the battery plate's are shorted due to lot's of vibration, no kind of charger can save it.
Old Jan 11, 2011 | 09:40 PM
rugerm44's Avatar
rugerm44
I have a battery tender junior on a 7 year old optima.It still shows 12.8 volts after being off the charger.Its in my boat.I also have the same battery in the vet with a battery tender plus on it now for almost a year with no problems.They wont bring a sufated battery back to life although I have a full size charger thats supposed to.
To Battery Tenders
